Most traction 255/50 kuhmo escta 712 or 245/50 yoko avs es100
I am going to running 10" coilovers, zg flares, on some 16x8 rims. I am looking for the most lateral traction. Personally I think the avs es100 stick better but they are also 0.8" thinner than the wider escta 712's. Also on the avs es100 I could also get 245/45 so that the tire size it same as stock, little less weight, and less side wall flex, but I would loose a little bit on the final drive ratio. So what one, the sticky smaller tire or the wider not as sticky but still sticky tire?
