No turn signals since swap
OK....when I did my swap I bypassed the fusible link setup (my fusible link cases were all corroded anyway) and am getting voltage to each of the red/white wires that had gone to the fusible links from the alternator.
There are two plugs under the dash that had been connected to the EFI harness, one is a two wire T type connector, the other is a 6 pin (I think) connector that has a red/white, black/yellow, etc...I can't find anywhere these connect other than the EFI harness...
I've checked to make sure all of my grounds are grounded, they are...but, for some reason I have absolutely no turn signals now...none in the front or rear, the lights don't even attempt to come on. It's like my switch is unplugged, except for the fact that it still switches from high to low beam...
Is there something I completely overlooked that you guys have run into before? Other than that the swap is running good (with the exception to the fact that in reverse my JTR driveshaft adapter grazes my rear sway bar, but, that should be fixed easily enough by shimming the rear differential).
Yo, Did you by any chance remove the center console/panel where the hazard switch is located, just a thought, because apparently the turn signals will not work without that switch being hooked up. Been there, done that........lol good luck!
