titanium Posted April 6, 2005 Share Posted April 6, 2005 I just used Cranes online cam site, I dont know much about my engine besides its a year 2000 vortec block #10243880 and a the head # 12558062. I put in the info I knew and they just recently sent me a reply saying I should buy this cam Part Number: 109831 Grind Number: HR-284-2S-12 IG Does this sound about right to anyone, what kind of gains did you see with your engine if you did get this setup? Thanks for any help. Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted April 6, 2005 Share Posted April 6, 2005 http://www.cranecams.com/?show=browseParts&action=partSpec&partNumber=109831&lvl=2&prt=5 heres the cam btw you did not post the rest of the combo in your question, gear ratio,trans stall speed, cpr, displacement, ETC and most of us DON,T keep track of your combo so the question is very difficult to answer correctly Quote Link to comment Share on other sites More sharing options...
titanium Posted April 6, 2005 Author Share Posted April 6, 2005 Heres a list of what he bought for the car, this is as much as I know so I hope this helps. New 2000 5.7L Vortec $1500.00 (block#10243880 head 12558062) Here is some info on the heads: Cast iron, The eight-bolt intake bolt pattern is totally different than the early model V8 12-bolt design. 2.02" intake and 1.60" exhaust. This head with the big valves flow better then the Phase 2 bowtie heads.Chamber volumes are 64cc and intake port volumes are 170cc. The Vortec heads have raised intake ports and "fast burn" chambers. The heads require the use of narrow body"self-aligning" rocker arms and center bolt valve covers. They will bolt to any Gen.1 block. The correct Vortec intake manifold bolts are found under PN-12550027. Use Vortec intake gasket PN-12529094. Edelbrock has aluminum two and four barrel "Vortec" style intakes that have the correct bolt hole positions. Edelbrock PN-7116 2000 Vortec 5.7 230HP $1500.00 1984 700R4 racing rebuilt $ 900.00 Mallory Unilite Dist(used) $ 130.00 (piece of trash. see below) Starter and misc brackets $ 272.74 Flex Plate ATP Z 166 $ 79.90 Water Pump GMB 130-1350short$ 61.40 JTR conversion book. $ 41.75 (shipping included) 3 cans yellow gloss paint $ 9.00 2 cans brown primer $ 6.00 Edlebrock intake manifold $ 183.95 pt#EDE7116 ARP intake bolt set $ 20.95 ARP434-2101 Hooker BL/Hugger headers $ 129.95 HOO2100 Chrome oil stick assy $ 7.23 SPC 4255 Chrome Trans stick assy $ 18.15 SPC 5472 Chrome timing tab for SBC $ 2.91 SPC 4263 Tail house extention 700R4* $ 198.03 GM# 8673406 Extention **** rod 700R4 $ 17.27 GM# 24210711/24214689New # Trans Mount 700R4 $ 25.25 GM# 475940 Motor Mounts (2 each) $ 99.00 GM# 3990332 Chrome dist hold down $ 4.97 SPC 4229 Chrome water outlet $ 13.13 SPC 4231 Holley pwr vlv saver $ 7.27 SPC 2408 Carb Stud Kit $ 4.98 SPC 4252 Ret Spring Bracket $ 7.08 SPC 4708 Lock Tight $ 7.72 PTX 64000 MCK carb dip 1 gallon $ 18.50 MCK 242 Carb gasket kit $ 5.25 SPC 680 More misc bolts+washers $ 28.95 JTR brackets...... $ 225.00 DAT-101-106+110 Temp Sender (240Z) $ 14.35 Holly fuel line $ 21.95 SPC-5952 15LB liq filled f/pressure $ 17.95 Oil spinner assy/filter $ 18.57 GM#3952301 Steel plates for trans br. $ 9.99 Steel for camber support $ 5.79 Drive Shaft $ 282.56 From Cannon Engineering Holley fuel line $ 21.95 SPC 5952 Mallory ballest resistor $ 12.99 CSI 700 1 wire alternator $ 45.05 FAE 7127U3 Chrome water pump pulley $ 50.77 MRG 4970 Chrome crank pulley $ 51.98 MRG 4972 Fuseable link for alt. $ 2.19 GM-#14 Rad hose upper? $ 10.40 GATES 20573 Rad hose lower? $ 13.03 GATES 21324 Alt/fan/crank belt $ 10.19 GATES 7485 6' hydr 3/8" hose for trans $ 15.22 Spal fans 14" + 10" $ 363.00 From Scotts Fans Valencia Ca CSI HEI dist $ 189.95 #66941 CSI HEI dist ends $ 4.50 Exhaust $ 495.00 2 into 1 3"- to 2stage flowmaster. Throttle cable parts $ 8.00 Holley 600DP $ 279.00 #4776-5 1 hr Dyno time $ 100.00 SWAT performance in Palmdale RearDisc $400.00 ish Modern-MotorSport Brake Lines for rear $ 32.04 CNS BH177695 Braded rear lines $ 60.00 Modern-Motor Sports R200 Rear 3.90 open $100.00 2 15X3.5" Centerline rims $100.00 Misc bolts ect $ 7.16 Centerline rims $300.00 15X8 rear 15X3.5 front CoilOvers from Ross $500.00 TOTAL ---------- $7650.22 Quote Link to comment Share on other sites More sharing options...
grumpyvette Posted April 6, 2005 Share Posted April 6, 2005 1255806298......350..........L31 Vortec, truck, 64cc chambers, 1.94/1.5, 170cc intake port.. 10243880...350...95-00...2 or 4...Vortec truck, Gen.I crate motors and "ZZ4", roller cam, one piece rear seal . http://www.goautocenter.com/zz4_420hp.htm CAM SPEC'S FOR 420 HP ROLLER ENGINE Duration @ .050" Lift Lobe Int. Exh. Int. Exh. Centerline 230 230 .560" .560" 110 http://www.cranecams.com/?show=browseParts&action=partSpec&partNumber=109831&lvl=2&prt=5 one of us (probably me in this case) is confused simply because part # for that block/engine shows the ZZ4 cam that comes with it is noticeably hotter than the crane cam your looking at??? Quote Link to comment Share on other sites More sharing options...
titanium Posted April 6, 2005 Author Share Posted April 6, 2005 Yeah, I dont know anything about it really. I thought I heard that the engine was pulled out of a truck. I'm wondering if the lack of information in the crane cam site caused it to come up with this specific one. If you can recommend something that would be awsome, I'm not quite sure what the converter idles at I think its around 2000 2500. I'll know better this weekend. His website mentions "and looking into GM Performance's HOT cam for the ZZ3 + 4 motors and new springs." If I can get a decent performance increse without getting new springs I'd go that route but if springs are a must to get any worthwile performance I'll wait a bit and get them. http://web.archive.org/web/20021211161354/nitrophotos.com/240z.html Thats all the info I could get on the car. THanks again for your help. Quote Link to comment Share on other sites More sharing options...
