what fuel pump should i use?
foremalaZ
i have a 1983 280zx and im doin a 81 turbo swap. i was wondering if i could use my na fuel pump, if not i was wondering what would be a good replacement performance pumb besides the zxt pump. thanks for any info and help
thanks luke
The one I purchased came with the inlet/outlets that worked for my application (280Z, which looks to be the "optionals" on that website). I am not sure what size hoses are on the 280zx, so I can't say for certain. If the '83 wasn't in the shop or the parts car was closer I could look, but it shouldn't take long to figure out what size you will need. If you have an FSM for your vehicle, it should tell you in the fuel delivery section.
I found that specific link using the search function on this site using the words "fuel pump" in about 2 minutes. Yes, sometimes the search function doesn't work, but when it does there is a wealth of info on this site. You may actually find the specific inlet/outlet size required for the zx from alittle searching if you don't have an FSM or access to your car at this time.
