Mounting BOV on Intercooler
Phyxius
I am considering mounting my greddy type S on the outlet end tank on my new IC. This would get it out of the engine bay and put it before my alcohol injection. I think that the end tanks are sufficiently thick to allow threading and flat enough to seal. I would be able to do this myself, thereby eliminating the cost of buying and having someone weld a flange to my new aluminum intake pipes.
Can anyone see any problems with this idea?
You can also solder aluminum. If you think the area where you want to install the BOV is too thin, solder piece of aluminum plate there and drill and tap both of them.
Aluminum can also be gas welded but I would not try this, it is how the original Cobra bodys were assembled.
