got hard to reach header to head flange bolts
first make VERY sure the hole in the header flange and the heads bolt holes align correctly and the exhaust gasket is not partly blocking the hole which are VERY comon problems, next make sure the bolts your useing are the correct thread type/pitch and length and before starting make sure the threads in the head are clear/clean, USE ANTI-SEIZE on the threads and make very sure the gaskets are correctly placed
once your TOTALLY SURE thats correct...a sidewinder wrachet and wiggle/wobble extension makes the rest reasonably (DO-ABLE)
http://www.jcwhitney.com/webapp/wcs/stor...catalogId=10101
http://www.jcwhitney.com/autoparts/Produ...ble%20extension
many times simply drilling out that particular hole in the header flange to the next larger drill size gives you enough room to get the bolt in much easier
BTW
on those applications where the bolt heads are so close to the header tube that turning the bolt becomes very difficult theres several ways to make that far easier
(1) socket head cap screw bolts
(2)studs with a nut, rather than a bolt
(3) (long studs with a nut or bolt and use a 1" or 1.5" long section of the correct size pipe or tubing slipped over the bolt or stud as a spacer to get the nut out away from the header pipe, this tends to work wonders when the clearance next to the flange is really tight
http://www.stockcarproducts.com/exhaust3.htm
Grumpy, You continue to amaze me with your knowledge and willingness to share it with us. I was making my down-pipes today and this post couldn't have been better timed. While lining things up I was wondering what would be the best way to get at the bolts, BAM, you give me the answer before I even ask.
Thanks
- Joe
