Griz Posted May 4, 2005 Share Posted May 4, 2005 DaleMX - You are correct, the 3/4 is the same as stock. The 13/16 was recommended to match the pedal throw and volume on the Hyd TO Bearing. The tube is created by McLeod (www.mcleodinc.com) and, according to the tech line person (714/630-3668), is created only by them to attach the Wilwood to the T56. Kind of pricey, (~$80) but also available at Summit and Street and Performance. LS1 Z - The number you listed is the same as I was using to search the web for. The parts available that match that number do not resemble the what I remember seeing online. I'll search out where I found it and check again, but the local auto parts cross reference component is NOT the way to go. Even the GM dealer, when given that number, comes up with a different part. It looks like there was a part number change without rolling the dash number or reidentifying the part. Hope this helps. Quote Link to comment Share on other sites More sharing options...
LS1 Z Posted May 4, 2005 Author Share Posted May 4, 2005 Me and others got ours from Scroggin and Dickey. http://www.SDPC2000.COM. Very hard to beat there prices. or you can call them at 1-800-456-0211. They also have the Z06 clutch set up at a great price! JOEY Quote Link to comment Share on other sites More sharing options...
