COZY Z COLE Posted April 27, 2005 Share Posted April 27, 2005 This shows how RIO VISTA MUFFLER mounted my modified new 60 in. PATRIOT sidepipes. The primary headers are 1 5/8 in. to 2 1/2 in. pipes and 2 1/2 in. collectors, the sidepipes are 3 in.. Right before the notched frame rails a flex expansion joint was added to take the engine twists and turns. The sidepipes are on hangers for easy removal of them. This set-up is flush with the body. Owner of the shop , BOB LAPP, did a great job. Upgrade to 10 lbs blower boost coming soon to a ricer near you...... LARRY Quote Link to comment Share on other sites More sharing options...
Turbo Meister Posted April 28, 2005 Share Posted April 28, 2005 Larry, Looks great. Does it sound any different? Or still as good as before? Hanns Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted April 28, 2005 Author Share Posted April 28, 2005 The loudness of them has been reduced and the idle has went from 750 to 600 rpms. I have no clue as to how old or how bad the internals were on the other set but I did have an exhuast leak on one. With the blower pulley change I'll be dynoing it and check the a/f ratio for adjustments. Have no fear I'll post a new dyno video and a "spanking" practice run video in the near future... LARRY Quote Link to comment Share on other sites More sharing options...
azguy Posted April 29, 2005 Share Posted April 29, 2005 How much ground clearance are you getting with that set-up? I need to redo mine when I get it back from the tranny shop. Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted April 29, 2005 Author Share Posted April 29, 2005 The exhuast pipes are 4 1/2" and the sidepipe cover is 4". The labor cost for removing old sidepipes, new custom mounting hardware, flex joints, and installation was $425.00 LARRY Quote Link to comment Share on other sites More sharing options...
titanium Posted May 9, 2005 Share Posted May 9, 2005 Sorry if this is a dumb question but does the exhaust on sidepipped cars ever cause premature tire wear on the rears? Seems like they'd get lots of heat in their direction. Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted May 9, 2005 Author Share Posted May 9, 2005 No....... LARRY Quote Link to comment Share on other sites More sharing options...
Guest 305240 Posted May 12, 2005 Share Posted May 12, 2005 Larry, where can I find a set of those flex joints like yours? Quote Link to comment Share on other sites More sharing options...
Sparks280zt Posted May 12, 2005 Share Posted May 12, 2005 Larry, not sure if you have fume problems in your Z, but have you noticed any with those side pipes? Quote Link to comment Share on other sites More sharing options...
COZY Z COLE Posted May 12, 2005 Author Share Posted May 12, 2005 305240 said: Larry, where can I find a set of those flex joints like yours? I'll get back to you later today...... Never had any fuel or exhaust fume problems. My problem now is the need for AFR heads on account of going to 10 lb boost. LARRY Quote Link to comment Share on other sites More sharing options...
