grumpyvette Posted May 16, 2005 Share Posted May 16, 2005 personally ID use JUST quality oil and a quality filter, Ive found the mobile 1 synthetic oil Im useing will be fine, I have always added a pint of MARVEL MYSTERY OIL to my oil but thats due to testing I did that showed it tended to reduce rust forming if I don,t run the engine for weeks at a time. MARVEL MYSTERY OIL is just a HIGH DETERGENT OIL, not an additive! changing your oil FREQUENTLY and using a QUALITY oil filter is the best protection your engine can get! read these http://people.msoe.edu/~yoderw/oilfilterstudy/oilfilters.html#recommended http://www.synlube.com/oilfilters.htm http://minimopar.knizefamily.net/oilfilterstudy.html http://www.micapeak.com/info/oiled.html http://www.nordicgroup.us/oil.htm http://www.geocities.com/MotorCity/Downs/3837/oilprime.html just a thought here, we have all seen those little gear/crank displays that you crank on the parts counter shelfs at the auto parts stores that show the oil stabilizer tends to make the oil cling to the rotating gears, well if thats how it works think about how the crank spinning may trap/control a good amount of the engines oil slowing its return to the sump at higher RPMS, (JUST WHAT ID SUSPECT YOU DON,T WANT) read this, its interesting http://www.bobistheoilguy.com/images/lucas/lucas.htm your thoughts GUYS??? Quote Link to comment Share on other sites More sharing options...
