Zoldman Posted May 19, 2005 Share Posted May 19, 2005 I'm having a custom tank built for my 260, and want to increase the capacity of the tank. I've looked at swaps and cells, but I've got a friend who will make me an all aluminum tank cheap. Anyone with custom tanks or fuel cells or swapped tanks have an opinion on the minimum height that the bottom of the tank should be from the ground? Right now my calcs put the bottom of my tank at 9", which is an inch higher than the bottom of the diff.......should be ok, right? Tank should hold about 19 or 20 gallons. Thanks Bill Quote Link to comment Share on other sites More sharing options...
johnc Posted May 19, 2005 Share Posted May 19, 2005 Maybe angle it up toward the rear to give you a little bit more clearance at the back of the car. Quote Link to comment Share on other sites More sharing options...
