increasing traction
grumpyvette
basically its simple, do a burn out then look closely at the black tire track, if the outer edge is darker it usually means your tire pressures LOW if the track shows the center darker theres usually too much tire air pressure (higher than IDEAL)the tire track left should be full tread width and equally black accross the entire width
your tires construction will have a huge effect on results and its rare for both tires to have exactly the same reqirements simply because the engine places a differant load on each, but Id start with about 22-24 PSI and work up or down from that point as the tire tread marks lead you
keep in mind doing burn out HEATS the tires and raises the tires air pressure so the tires air pressure drops slightly sitting in line waiting for the next run
BTW look at TRACTION COMPOUNDS
http://www.jegs.com/cgi-bin/ncommerce3/ProductDisplay?prrfnbr=3897&prmenbr=361
no! before you bother to ask, bleach does not work just as effectively
