Flow numbers on MN47 Head.
1 fast z
So I am jumpin in and getting some of these customers MN47 heads done, (I have 3 in here for guys right now). I did a some what of a street port, which means only raising the intake port about .160". There is also ALOT of internal work, that is some what tricks that I like to hold on to. But anyways, both of these test were done with the stock 42mm valve, and not the 44 mm intake valve, like All 280's have. I will put the bigger valves in tommorow, and get new test numbers.
The ratings were all taken at a .200" starting number, and then they go up in .05" incriments from there. All CFM Ratings are done at 28" of water.
Here are Modified numbers:
106.5
125.4
142.0
153.8
168.0
177.5
191.7
198.8
203.5
210.6
215.3
Here are Stock numbers:
99.4
123.1
132.5
146.7
156.2
165.7
170.4
175.1
175.1
175.1
175.1
