proxlamus© Posted June 4, 2005 Share Posted June 4, 2005 Hey guys.. I just finished my turbo swap... and I started her up this morning and she idle'd and ran fine... and it revved great!! BUT when I backed her out into the street and put it in first gear and started to engage the clutch the engine started cutting out and died... What could be wrong with it? I checked all electrical connections that I could and I checked for spark and good fuel pressure and it's fine.. But what the hell could be wrong with it?? here are some pics Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted June 4, 2005 Author Share Posted June 4, 2005 Ok... something new... It WONT rev past 2,000 RPM... Which is why when I try driving it wont run past 2,000 RPM... hmm I have an FSM actually for my car.. i tried looking.. and no luck.. I also unplugged the TPS to see if it was bad .. but it still didnt run past 2,000 RPM with or without the TPS... I didn't swap in a WHOLE new engine.. I just used my stock N47 head and block which was already in my car and I did a manifold swap... and with some 310cc injectors Quote Link to comment Share on other sites More sharing options...
Tony240ZT Posted June 4, 2005 Share Posted June 4, 2005 If it were the tps you wouldn't be able to rev it while parked either. I had a similar problem after a long swap, ended up being fuel delivery problem due to the gas gunking up from sitting so long. Fuel presure guage verified the problem. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted June 5, 2005 Author Share Posted June 5, 2005 ok.. i am running overly overly rich.. i swapped out the 310cc injectors and put back in my N/A injectors and I will run low boost... havent driven it yet but it runs and revs fine Quote Link to comment Share on other sites More sharing options...
SR240Z Posted June 5, 2005 Share Posted June 5, 2005 you could also lean out the AFM with the 310cc injectors. Quote Link to comment Share on other sites More sharing options...
proxlamus© Posted June 5, 2005 Author Share Posted June 5, 2005 I leaned out the AFM about 35 teeth.. and still no luck... it's ok.. N/A inject are in Quote Link to comment Share on other sites More sharing options...
evildky Posted June 5, 2005 Share Posted June 5, 2005 check the CHTS, also if you plan on running larger injecotrs with the stock managment system you have an adjustable fuel pressure regulator and guage right? if not get one if so turn the pressure down, look for leaks in your intake tract from the maf to the throttle, check the many fitting and piping on the intake, most likely the problem is staring you in the face you just gotta stare at it till you see it at least thats how most of the problems found me, also be weary of the stock fucl pump if your using it, it took me a while to diagnose mine was shutting down under boost Quote Link to comment Share on other sites More sharing options...
