grumpyvette Posted June 14, 2005 Share Posted June 14, 2005 "IM building a 496 stroker from my 454 engine in the corvette, I read somewhere that the 4.25 stroke of this engine will boost the compression a little more than the standard 4.00 stroke. Is that true? I thought that if I used the 10-1 pistons that are MADE to be used with the 6.385 rods, my compression would be the stated 10-1. Any thoughts? " first Id point out that your comparing apples & oranges to some extent, if you had flat top pistons designed for either engine with the came deck height, valve notches,etc, but the correct pin hight for the application, or for that matter any pistons with identical dome displacement, and you use the same cylinder heads with the same combustion chamber size, increasing the stroke will increase the compression simply because youve increased the sweep voluum between bdc and tdc, play with this calc, change only the stroke on any combo and look over the results http://www.csgnetwork.com/compcalc.html now once you understand that approach, you need to understand that the compression and dome height IS by design DIFFERANT on the 10:1 pistons for a 4" stroke and a 4.25" stroke piston designed to have 10:1 compression. both will have aproximately 10:1 cpr in thier intended application, but the pin heigh,ETC. will differ a great deal now it may help if you play with these calculators (below) http://kb-silvolite.com/calc.php?action=piston_comp http://kb-silvolite.com/calc.php?action=deck http://kb-silvolite.com/calc.php?action=piston http://kb-silvolite.com/calc.php?action=comp2 keep in mind the blocks deck and crank centerline stay constant if the blocks deck is 9.8" from the crank centerline and you have a 4.0" stroke with a 6.135" rod youll need a 1.665" pin height in the piston if the blocks deck is 9.8" from the crank centerline and you have a 4.25" stroke with a 6.385" rod youll need a 1.29" pin height in the piston Quote Link to comment Share on other sites More sharing options...
