yoogener Posted June 15, 2005 Share Posted June 15, 2005 i ammmmm completely new at dealing with weatherstripping but im willing to learn. i started the replacement process starting with the qtr windows figuring that it should be done before the door seals. i got the inner qtr window seal and the metal frame on. the question is... do i put the outer qtr seal on the window first, and THEN on the body? or vice versa? and is the taller leg towards the outside or inside? if i'm not following the correct order of seal replacement, feel free to provide with the right steps thanks a lot Quote Link to comment Share on other sites More sharing options...
