Guest shodog Posted June 17, 2005 Share Posted June 17, 2005 dudes, i have a roll bar that mounts on the rear wheel wells. it did not come with any mounting hardware since it was used. does it have brackets or a plate on the wheel side or am i to use washers and bolts? thank you, cory. Quote Link to comment Share on other sites More sharing options...
Guest shodog Posted June 17, 2005 Share Posted June 17, 2005 oh yea, i have a 1975 s30. Quote Link to comment Share on other sites More sharing options...
spotfitz Posted June 17, 2005 Share Posted June 17, 2005 Yes, there is a backing plate that the bolts go through on the wheel side. Mine are about 1/4" thick if I remember correctly. Quote Link to comment Share on other sites More sharing options...
Phantom Posted June 17, 2005 Share Posted June 17, 2005 Roll bar is probably made by Autopower. MSA sells them. I have one also and the backing plates are about the same thickness as the mounting plates on the roll bar. Quote Link to comment Share on other sites More sharing options...
PeterZ Posted June 17, 2005 Share Posted June 17, 2005 Please consider putting a radius on all flanges that contact the sheetmetal of the car. If you should have the terrible misfortune to turn the car over a sharp edged flange can cut through your car like a can opener during a time when you need your roll bar the most. On the bars I have used the flanges you are missing were the same size and thickness as the ones welded to the tubes. Quote Link to comment Share on other sites More sharing options...
Guest zfan Posted June 18, 2005 Share Posted June 18, 2005 Thats a very good idea, I never thought of that. Of course I no longer own one, welded in cage now. Mike Quote Link to comment Share on other sites More sharing options...
Guest shodog Posted June 18, 2005 Share Posted June 18, 2005 thank you for your support of my habit. your information I have found useful. thank you again all of you, shodog Quote Link to comment Share on other sites More sharing options...
