Having trouble loading code
ihatejoefitz
I have nearly everything hooked up and I can hear the Relay power up but the red light does not light up.
When I hook it up to the computer it says that no setting are detected or something like that.
Any Ideas?
I have the Msns code preloaded from rsautosports. This is on an 83 280zx turbo.
I would recomend using hyperterminal to reload the firmware, I had some problems getting it to "seem" like it was working, but after I did a "wipe" and sent the new firmware to it, everything came up. Make sure that you are using a compatible version of MT. http://not2fast.wryday.com/megasquirt/ is a good site for all versions of firmware and software. Let us know if you need instructions for reloading the firmware.
