Phyxius Posted July 20, 2005 Share Posted July 20, 2005 you definitely need the main board and stimulater (unless you know someone who would let you borrow a stimulator). The relay board is optional, but it does make things a bit cleaner to install. Quote Link to comment Share on other sites More sharing options...
badjuju Posted July 22, 2005 Author Share Posted July 22, 2005 So those two are the only things i NEED to get it running, but a relay board is good also? Quote Link to comment Share on other sites More sharing options...
RacnJsn95 Posted July 22, 2005 Share Posted July 22, 2005 You don't NEED the stimulator (although it is recommended if you are building it yourself), it just so you can test everything and see if it all works correctly, without it being in the car. The relay board is basically an "external" power realy (with fuses) so you don't get some crazy surge and blow the MS. He totally missed the option of skipping the distributor option altogether, installing a Plug in the Dizzy Drive hole, sticking in an LD28 Oil Pump stubdrive spindle, and using the MS-n-EDIS option after installing a 60-1 Trigger Wheel! How exactly does that work, and what is a 60-1 trigger wheel? Quote Link to comment Share on other sites More sharing options...
spineless Posted October 19, 2005 Share Posted October 19, 2005 Did anyone ever try getting the MS to work on a stock 81zxt setup with the MSns extra that was mentioned above? This thread got me really thinking about doing the megasquirt thing if it could be done easily in the stock 81 zxt. Quote Link to comment Share on other sites More sharing options...
