Help...putting the LSD in the case..
Airjockie
I got a 4.11 r180 from the 4X4 truck, got a Nismo r180 2 way LSD, and now I got to install it.
I swapped the ring gears already, and now I am at a point to where I should just finaggle it into the case....
but...it goes in partway...and hangs up on the case. Due to the larger shell case of the LSD.
I have tried to install it with the ring gear off...and it slides right in...
I have removed the ring gear, and put it in first, then tried to slide the LSD thru it and into the diff case...but hangs up...
Is there a simple trick to getting this diff together?
