Turbo Swap, Dizzy Help
Kraker_Jax
Got the intake manifold off tonight, then I took off the dizzy. People said to lock up the mechanical advance. Sooo JB Weld to the rescue! Now, what exactly do I weld up? Also I think some bearings popped out, and a part that holds one of them in broke also.... Hope this is not too much of a problem... Thanks for the help! Sorry for the blurry pics, mom's cam isn't all that great...
I bet the ball bearings that work the vacuum advance fell out along with the plastic cage that holds them inplace. This is fairly common on these dist. You'll have to pull apart the dist. to check it out. Use this website as a guide
http://www.jrdemers.com/280ZX/distributor/distribase.html
Actually I like the mechanical advance on mine. If you want to limit or cancel the mech advance, you have to close up the slots that the two pins move in. You can see them in the first pic of yours. Hope this helps.
