What should I bead blast?
jmark06
There is a bead blaster where I am working this summer, and I am wondering what all I should blast while my engine is dissasembled. I don't know what can be damaged and what can handle it. The block and head are already cleaned, but can I do the pistons, manifolds, or anything else?
Around here a bead blaster is understood as a glass media blaster. It works very well on any aluminum parts but not as good on steel or cast iron. Aluminum oxide works best for that. I do entire cylinder heads with glass media, but that's with everything removed including the cam towers.
I say as a general rule of thumb avoid any machined surfaces unless you had already planned on machining them again. A couple layers of duct tape over any areas you don't want affected works well.
