24 oz Posted August 19, 2005 Share Posted August 19, 2005 I have a 77 302 and i was wondering how much power it had and what it redlines at? Quote Link to comment Share on other sites More sharing options...
Mike kZ Posted August 19, 2005 Share Posted August 19, 2005 Welcome to the site! This is from a web page I found: "1977 King Cobra Mustang II package that came with a 2-bbl 8.4 compression 302 V-8 that was rated at 139 hp at 3,600 rpm and 250 lb-ft of torque at 1,600 rpms." Quote Link to comment Share on other sites More sharing options...
24 oz Posted August 19, 2005 Author Share Posted August 19, 2005 Damn thats pretty week what about an 88 302? Quote Link to comment Share on other sites More sharing options...
Guest Turbo_Lag Posted August 25, 2005 Share Posted August 25, 2005 You have to remember to- in '77 that much as little as it seems, was magnificent for stock. Josh Quote Link to comment Share on other sites More sharing options...
TomsCoupe Posted August 25, 2005 Share Posted August 25, 2005 Here is a post that i made a while back about the 5.0's. this should give you more than enough info to make a decision on which year 5.0 is best for you. IMO' date=' the best 5.0 engines are the 89-92 engines. The86-88 use Speed density(unless its a california car, in which case it runs mass air which is a good thing) and 93-95 use crappy Hypereutectic pistons. 79-84 -175hp rating -non-roller blocks 85 -first roller block -600-cfm Holley carb -210 hp rating (automatics still used CFI) 86 -roller block -forged pistons -first year of speed density(not a good system) -stiffer block -crappy heads 87-88 -roller block -forged pistons -First year of the E7TE heads which are pretty good for a stock head. -still uses Speed density -225hp rating 89-92 engines(88 california cars have mass air too so they are good as well) -forged pistons -roller cam -mass air(much better than the speed density that came with the 88-below cars) -225hp rating 93 -changed to Hypereutectic pistons -power drop to 205hp 94-95 -HO engine with E7TE heads -Hypereutectic pistons (not sure about power rating) hope that helps[/quote'] Quote Link to comment Share on other sites More sharing options...
