24 oz
Here is a post that i made a while back about the 5.0's. this should give you more than enough info to make a decision on which year 5.0 is best for you.
IMO' date=' the best 5.0 engines are the 89-92 engines. The86-88 use Speed density(unless its a california car, in which case it runs mass air which is a good thing) and 93-95 use crappy Hypereutectic pistons.
79-84
-175hp rating
-non-roller blocks
85
-first roller block
-600-cfm Holley carb
-210 hp rating
(automatics still used CFI)
86
-roller block
-forged pistons
-first year of speed density(not a good system)
-stiffer block
-crappy heads
87-88
-roller block
-forged pistons
-First year of the E7TE heads which are pretty good for a stock head.
-still uses Speed density
-225hp rating
89-92 engines(88 california cars have mass air too so they are good as well)
-forged pistons
-roller cam
-mass air(much better than the speed density that came with the 88-below cars)
-225hp rating
93
-changed to Hypereutectic pistons
-power drop to 205hp
94-95
-HO engine with E7TE heads
-Hypereutectic pistons
(not sure about power rating)
hope that helps[/quote']
