82' L28et Distributor
oinojo
you can't just drop an N/A dizzy into that engine. you would also have to change the distributor drive shaft as well. the '81 turbo had the cas on the crank, and the '82-'83 turbo have the cas built into the dizzy itself. are you doing a full stock swap (ecu, harness, engine), or are you doing something else? I don't think the '82 ecu would run with an N/A dizzy.
okay thats what i needed to know thanks... but yeah im swapping the whole motor in. Im looking into megasquirt for my FMU.
