grumpyvette Posted August 22, 2005 Share Posted August 22, 2005 I was asked if adding an adjustable fuel pressure regulator helps, on those TPI engines... naturally the results depend on your application and combo, as an example on the 1985-1996 corvette I useually work on...your engine power is regulated to a large extent by the rate at which you can EFFECTIVELY BURN fuel/air mixture the adjustable fuel pressure regulators can in some combos help noticably IF the injectors used are running at the ragged upper edge of thier flow limits, but in most cases they do very little, WHY?? well the cpu controls the injectors pulse width effectively controlling your air/fuel ratios from feed back from the O2 sensors in the exhaust, at least in theory the injectors are large enought to supply 100% of your engines potential needs running less than 80% pulse width. at the 37psi-42psi the stock regulator provides. BUT if youve made significant changes to the engine combo youll need to EITHER increase the injector size OR cheat by upping the supply pressure to those smaller injectors, obviously adding more pressure with a regulator is limited to the maximum the fuel pump can supply and in most case the stock pump maxs out just under 48psi play with this http://users.erols.com/srweiss/calcpchg.htm youll soon find that useing larger injectors and letting the CPU REDUCE the pulse width is far more effective that trying to boost flow on stock injectors Matching the Injector to the Engine: generic calculation Injector Flow Rate (lb/hr) = Engine HP x BSFC Number of Injectors x 0.8 Injector Size 14 lb./hr.......up to 225 19 lb./hr.....225-300 24 lb./hr.....300-385 30 lb./hr......385-480 36 lb./hr......480-575 42 lb./hr.......575-670 50 lb./hr ......670-800 Horsepower Range http://go.mrgasket.com/newproducts/flyers/74098G.pdf http://www.fiveomotorsport.com/Injector_SetsTPI.asp __________________ retired engineer ,engine builder, 1985/92/96 vettes(all modifyied) Quote Link to comment Share on other sites More sharing options...
