twin turbo?
24 oz
I have a ford 302 and was thinking about putting on twin turbos. I want to do this really cheap and buy some used turbos and then try to make everthing that i need. im not worried about the oil lines that should be easy but i was wondering what about headers and an intake what should i do about that??
weld a flange to the headers if you want to do it on the cheap, other wise you'll need to do custom exhaust manifolds which can cost or you could weld some flanges onto the stock exhaust manifolds.
are you planning on going i/c? also you might want to consider a low compression rebuild if you plan on making any serious boost.
also are your turbos going to be parallel or in series?
and when buying your used turbos, be very careful. there could be lots of things wrong and they may have to be rebuilt.
you got a lot of research to do on this subject guy
