EvilC Posted September 10, 2005 Share Posted September 10, 2005 Hey guys, I am in my senior yr now and of course doing the engineering thing we have senior desing projects. After a few weeks of thinking it finally came to me that I should use my 240 for my senior design......so what do I need.... 1) I need the specs of what the stock 240z braking power is meaning the distance from different speeds it would take the car to stop and maybe exact size of the rotors and brake pads....I looked here found different numbers plus my car is 4 hours away =) 2) Is there anyone or anywhere I can get stress/strain numbers on the chassis of the car. I have to prove the work I am doing does improve the cars safety and structural intergrity. My plans are to upgrade the bakes...with the wilwood kit.....roll cage weled in, and sub frame connectors wit frame rail supports. Thanks for any help guys! Quote Link to comment Share on other sites More sharing options...
TheNeedForZ Posted September 11, 2005 Share Posted September 11, 2005 April 1970 Road&Track Road Test Datsun 240Z -----General(I only list relevant info)----- Curb weight,lb.....2355 Test weight........2769 -----Brake type----- 10.7" disc front. 9.0"x1.6" drum rear, vacuum assisted Swept area, sq inch.....310 Wheels.....steel disc 14x4-1/2J Tires.....Bridgestone 175 SR-14 radials -----Panic stop from 80mph----- Max deceleration rate, % g....84 Stopping distance, ft..........287 Control......................excellent -----Fade Test : percentage increase in pedal effort to maintain 50%g deceleration rate in 6 stops from 60mph.........10 -----Parking : Hold 30% grade?.....yes Overall brake rating.....very good Quote Link to comment Share on other sites More sharing options...
EvilC Posted September 11, 2005 Author Share Posted September 11, 2005 Hey thank you very much for the info. Quote Link to comment Share on other sites More sharing options...
