Guest Battle Pope Posted September 12, 2005 Share Posted September 12, 2005 1: My '76 has an '82 ZX engine, which means it has the ZX distributor. I'm almost done with the install on my carbs. All I need is a PCV line and to wire the distributor. Can anyone tell me which wire from the dizzy is which polarity to the coil? That's my biggest problem. 2: Is it necessary to have the coolant temp sensor wired in to make the car run and drive? I wouldn't think so because the carbs are controlling the fuel and air source? My apologies for the noobish questions, and thanks to anyone who can help. Quote Link to comment Share on other sites More sharing options...
fastzcars Posted September 12, 2005 Share Posted September 12, 2005 doesn't the 82zx engine have fuel injection? As a matter of fact the 76 does too. What carbs are you using? Quote Link to comment Share on other sites More sharing options...
Guest Battle Pope Posted September 12, 2005 Share Posted September 12, 2005 I got a pair of DGVs, the cannon manifold adapters and 260z runners with linkage for 300 bucks, with the carbs professionally rebuilt. The FI didn't work and the wiring looks like a victim in a slasher film, so I took the easy way. I found a pic elsewhere online delineating the polarities on the "black box" and coil, so I'm left with the water temp sensor question. Quote Link to comment Share on other sites More sharing options...
