Gauges in an SR20DET 280Z?
Lewis Maudlin
Guest PROJECTRB240SX
I have a stock speedo in my car.... Although I can't lend a hand in how to get it to work but I know vildini knows of a way to get it to work.
On a sr20det there are three required gauges in my opinion Water temp, Oil pressure, and boost.... everything else is additional.
since we are on the topic of gauges....
Alex how do you guys convert the speed sensor to work with the stock gauge? I want to go to an adjustable Electric speedo so I can adjust for the tire size and diff ratio that is far from stock. If you don't want to release this I understand, I'm just trying to figure out if you altered the trans speedo sleeve or just the sensor drive used.
  • 3 months later...
I have no personal experience with this in particular, but I know the 280z tach are triggered from the (-) side of the coil.
But then again, they've been known to be inaccurate.
Why not replace it? Someone on here got a smaller tach and placed it in the stock location. Looks great and is accurate.
Just my opinion,
Mario
