Guest grimlynsan Posted October 5, 2005 Share Posted October 5, 2005 I have been searching for this information but all that seems to happen is that I get more confused. In brief: (I have a RHD '77 260z 2+2) I am aquiring some zg flares. I will be cutting the guards and welding them together. I want to buy some new 17" wheels and the WIDEST tyres I can get front and back. These are the rims I want: They are made by ROH and are available up to 17X12. Here is where it gets more complicated. Up front i have done the toyo brake swap and in doing so have switched to 240k hubs. Keeping in mind that I wish to lower the car, what offset and width should I order the wheels in? The same question applies to the rear however I have upgraded to R31 skyline bracket, discs and calipers. What offset and width should I order the wheels in? What is the maximum tyre width? I want to fill the flares front and rear. I can get bolt-on adapters made up if I have to. I really appreciate the effort it may take someone to respond. Thanks in advance. Quote Link to comment Share on other sites More sharing options...
toecutter Posted October 5, 2005 Share Posted October 5, 2005 I just bought a set of 17x8.5 (-6offset) & 17x9.5 (-19 offset) ROH venturo for my 260 which will be used with ZG flares. (Tyres, 225x45x17 frnt & 255x40x17 rear). Theres a lot of variables added to the equation with those changes you've made. I think your safest bet would be to measure how much room you have.Take a straight line up from the hub face and measure perpendicualr from that to the spring perch. Do a search on offset info and you should be able to work out what offset you need. The only issue will the caliper clearance. Oh and note that a 9.5 inch rim is actually 10.5 when measured from the actual ends because the wheel shops always measure from the bead! I hope somebody can give you more advice than I have. Good luck! Sulio www.viczcar.com Quote Link to comment Share on other sites More sharing options...
