More Noob Q's?
Guest sho_shane
Guest sho_shane
Ok sorry if theses are repost q's.
1. Iv seen a Z or two that had no front bumper and some kinda grill in the front and it looked alsome. I want to know if anyone has done this and if they have pics?
2. Iv seen Z's that look like they have a roll pan in the back but I cant find anywhere on the net where there is a kit. Can somone please tell me how this is done?
3. Is it save to turbo an N/A 76 L28E motor and if so how much boost can I run?
4. Does my 76 280Z have a LSD Rear End?
5. How low do you guys lower your Z's for the best handling?
6. What is it better to do with a Z Drag race or Road race?
Thanks for any and all help.
and agin im sorry if theses are a repost!!!!
First off if you use the search function all your questions can be answered.
1. Go to the photo album and look through there, tons of Zs like that, www.zcarparts.com sells some front valences as well
2. There is no kit, all custom
3. Yes, it has been done. Search for the details
4. Nope
5. Search, lots of options like lowering springs, coil overs, etc
6. There is no better way, its what you wanna do
Guest sho_shane
Were you thinking something like our billet grille I custom fit? Hated the front bumper look and plus it got rid of 30 lbs of weight.
That is just what im looking for how did you do it and what did you use?
im pretty sure brian got a chevy astro van grill and cut it to fit his 240, but ill let him fill you in
Yes I bought a new billet grille for a Chevy Astro van off Ebay for $40 (I think it was for 84-89 years but cant remember exact year span). We had to remove one of the tubes and the 4 mounting brackets, and then mounted it upside down (You will have to make your own brackets to mount it). We also had to do quite a bit of measuring and trimming with tin snips of each side to follow the contour of the edges of the fender and headlight buckets. It wasnt a quick easy job and I am surprised we got it on the first try on the cutting and it actually fit pretty good.
It does look mean as heck when its coming up behind you in the rear view mirror. Most people think its got a v8 under the hood because ofthe huge grille.
Guest sho_shane
Well agin your car looks alsome. Can I ask, im thinking about getting rid of the FI and going with a set of triple carbs are they hard to keep in senk?
The triples are very easy to keep in synch. We synched them when it was dynod 6K miles ago and checked them last month and they were still fine.
We bought a nitrous fogger kit for it and were going to throw a 175 shot on it, but it never was installed. The cops around here are towing cars if they are pulled over and found with nitrous hooked up and I figured forget it. Aready got pulled over once and it almost got towed for the modded engine it had.
