tesk-top dyno anyone?
If anyone has a desktop dyno could you please enter these specs in and see what kind of power you come up with thanks. 307 ci 3.9 inch bore, 3.25 inch stroke, 9 to 1 compression, 1.94/1.50 inch valves, mild port work, .454 in lift, 205 duration at .050, GM egr four barrel intake manifold, holley 600cfm spread bore vacuum secondary 4 barrel, chevy points distributor, Z/28 windage tray, 1 5/8 long tube headers(this is with no fuel pump or fan)sorry i am not sure on the piston design of the 307 just figure 9 to 1 compression, the heads are 76cc chambers
Thanks Alf! I love the first gen Camaros. That is the first car I ever renovated... Learned a lot doing it, and will probably redo it once my Datsun is finished.
Nope, haven't had it down the 1320 yet... I've wanted to for awhile now, but if it isn't one thing it is another. Hopefully I'll be able to get it out some year! My goal with the current engine is mid 12s at 110-115mph.
yeah my camaro is the first car i have restored so far, ive had it since i was 15, i love first gens. the best my car ever ran was 12.82, it also ran a 12.87 on a 95 degree day after i added a msd 6al and a carter fuel pump, so im figuring 12.7s and maybe 12.6s in ideal conditions. the only difference besides minor engine differences is that my car is a four speed. you can probly expect the same when you go, you gotta have slicks though cause it will just smoke tires all day which you probly already know.
