Sandblasting on a budget.
MusPuppis
I figured as much.
I was thinking of using some plastic sheeting in my garage to make a generic little room around the peices that I blast. That should (hopefully) contain it in some way atleast and allow me to collect and reuse the sand. If I can anyway. Its my understanding its good for about 2-3 uses before it becomes to fine to do much.
I just bought the 40lb unit from them. On sale for 84.99 plus a 20% off coupon.
Containment: I use it on a sheet in the yard and then recycle the sand with a kitchen strainer and funnel it back in. Lose about 25-30% of the sand each cycle, as it blows off the sheet.
Quality: The moisture seperator broke the 1st day when I tried to open it to drain the water, and the shutoff valve at the discharge end of the hose stopped working about 5 minutes into use. The internal parts are made of plastic and just chipped away with the sand coming out. I bought a replacement valve from home depot and it failed quickly too. I wound up buying a deadman type nozzle from harbor and its working well now.
I've got a similar thing, does work well, but it does stretch my compressor (3hp/100ltr). I built a plywood cabinet to try and contain the sand, it sorta does but I still end up looking like I've spent a few days in the desert ;)
For sand, I just use patio sand, now what you guys over the pond would call that I don't know, but it's fairly fine, free flowing stuff, so none of your coarse stuff for mixing concrete with. I buy it in 20kg bags at the local DIY chain store. It has to be bone dry though otherwise it can block the various taps which is a PITA. I recycle probably more times than I should do, apparently once the sand gets broken down in to super fine particles it's quite a dangerous health hazard as when breathed in it won't come back out, worse than asbestos which is a nice thought. So get a very good filter mask!
Cheers,
Rob
For sand' date=' I just use patio sand, now what you guys over the pond would call that I don't know, but it's fairly fine, free flowing stuff, so none of your coarse stuff for mixing concrete with. I buy it in 20kg bags at the local DIY chain store. It has to be bone dry though otherwise it can block the various taps which is a PITA. I recycle probably more times than I should do, apparently once the sand gets broken down in to super fine particles it's quite a dangerous health hazard as when breathed in it won't come back out, worse than asbestos which is a nice thought. So get a very good filter mask!
Cheers,
Rob[/quote']
Awesome! Here our megalomart super home centers sell playground sand, which is probably the same. I'm gonna buy a bag and try it, its definitely better than the $20 for a 25lb box of alum.oxide.
I use slag (residue that is left from arc welding) a bag of it is like $15, good for general striping. Then I use 30/70 or 70/30, I forgot for finer stuff. Just remeber to get a pair of media blasting gloves and a suit, it gets EVERYWHERE.
