niner11 Posted October 31, 2005 Share Posted October 31, 2005 Been searching a lot but not sure if the 82/82 distributor is completely self contained. I have seen pics of the earlier (81) model and it has external teeth on the crank pulley and a sensor. Trying to confirm if the later dizzy can be stand alone. I'll probably be wiring my set up like Moby so it will have the hei module but other than that I need more info on 82/83 dizzys Thanks, Chuck Quote Link to comment Share on other sites More sharing options...
olie05 Posted October 31, 2005 Share Posted October 31, 2005 from what i've read, its the 83 the dizzy that has the built in CAS, not the 82,81. Quote Link to comment Share on other sites More sharing options...
Thumper Posted October 31, 2005 Share Posted October 31, 2005 The 82 and the 83 turbo distributor had the internal cas. Either one of those can be used when you go standalone. Only the 81's had an external one. But even then you can use one of those if you want to. I will just take alittle more fabrication. Quote Link to comment Share on other sites More sharing options...
olie05 Posted October 31, 2005 Share Posted October 31, 2005 sorry, I stand corrected... *bows down to master of tuning* Quote Link to comment Share on other sites More sharing options...
niner11 Posted November 2, 2005 Author Share Posted November 2, 2005 Thanks guys for the info. Just so I know how to configure my MSII, are the cas sensor dizzys(82/83 models) "Hall Effect" sensors? It looks like MSII can run my spark without an external 7 or 8 pin HEI but I'm not sure yet. Chuck Quote Link to comment Share on other sites More sharing options...
mobythevan Posted November 2, 2005 Share Posted November 2, 2005 They are optical encoder wheels Quote Link to comment Share on other sites More sharing options...
niner11 Posted November 4, 2005 Author Share Posted November 4, 2005 Thanks, I needed to know what it was so I can configure the MSII correctly. Quote Link to comment Share on other sites More sharing options...
