Spark output
afbrian13
I everybody. Figured I'd post this here. I have a 76280z with 82zxt motor and wiring harness. Motor cranks fine, getting fuel flow from injectors, but no spark. The coil itself is good, but I'm not sure how to test the mag. pickup in the dizzy.
I also don't think I'm getting correct output from the ecu. Should be pin 5 from the ecu to the transistor on the side of the coil. I changed the transitor out. Just to let you know, I've checked all wiring and it is good.
My conclusion: Mag pickup in distributor, or ecu.
what is the best way to test and find out. What meter readings should i be getting at different outputs. Thank
Brian
