Upgraded 195 AFR Heads
Decided to change a few things....
Comp Cam bee hive springs.
Comp Cam 1.6 Pro Magnum roller rockers.
Cometic .040 head gaskets.
Special machined spring locators.
Increased lift from .480 to .512.
Last dyno was 405 rw ft. lbs., we'll see what this does in a couple weeks when they get installed. In a couple months I'll do a cam and torque converter change.
Info on the bee hive springs....http://carcraft.com/projectbuild/116_0403_mail/
LARRY
Nice looking setup. Beehives are a good idea.
How much seat/nose pressure are you running?
How much side to side play do the comp rockers have between the body and the snap rings on the shaft?
John
Thanks for the comments.......
Seat pressure...147#
Over the nose...316#
Side to side play.... .010 to .015
LARRY
