oinojo Posted November 19, 2005 Share Posted November 19, 2005 okay for the main relay i have it connected for the (on) position on my ignition. I also have the fuel pump relay in the same location for #86 (yellow)on the relay. Is this correct or is MS suppose to be connected to Accessories? I know its a dumb question but i still cant connect to my MS unit with my laptop and im trying to work out some way to get it to work. yes i realize it would be easier to just buy a stim board but if anyone could help me out without using it would be great. I dont have 75 bucks spare for me to buy a stim. Quote Link to comment Share on other sites More sharing options...
ngrimm Posted November 20, 2005 Share Posted November 20, 2005 I am no expert, I recently assembled my 1st MS 2.2 board but I have several years in electronics. First thing I would verify that the com port is communicating with the MS. If you go to the assembly instructions http://www.megasquirt.info/v22manual/mass.htm#guide you will find instructions for jumpering pin 2 and 3 on the db9 serial connector that connects to the MS and testing the connection with Hyperterminal. If that works I would verify that I had 12 volts to pin 26 on the MS db 37 connector when the ignition switch is on. Of course I would check the ground connections to the MS and relays. BTW I think you want power to the pin 86 on both relays both in the start and run position but not in the accessory position. Good luck. Norm Quote Link to comment Share on other sites More sharing options...
