85 180 4X4 4.38 axle carrier/240Z stubs work?
Hi, First post to the list, I am building a E production 240Z . My question is will my 240Z stub axles work on this late a production rear end with out modifaction? This is the front reversed 4.38 4 wheel drive punkin. Pulling it tomorrow from the local you pull it, so a quick response would be appreciated. Love this no BS list. Thanks in advance DC
The diff you're pulling most likely uses the snap ring stub axles and the 240Z stub axles are most likely the center bolt type. Both will fit the splines. Get the stub axles with the diff. You can use them if you replace the u-joints on the halfshafts or you can machine a couple buttons with threaded center holes and bolt them to the end of the 240Z stub axles. Cut a snap ring groove in the buttons at the proper depth.
