Good turbo upgrade L28et?
Big Z
Hello all,
I have read a lot of posts of getting a bigger turbo to replace the stock T3. Unfortunaly, due to all the posts i can't really any info on this turbo.
I am currently busy with collecting parts to build my L28 et to +/- 350 crank power goal. I already have an alu IC, 444cc injectors, and now i'm able to buy a good (200 miles) used turbo (from a Ford cossworth).
The specs are following:
Garret AirResearch
Type: T04B28
s/n: FD0102A
465.288.3
intake side compressor:
external diameter: 70 mm
inside diameter at entrance of the compressorwheel: about 45 mm
Compressor output:
outside. dia.: 51 mm
Inside. dia.: 43 mm
Code on compressorhouse: AR60
Code on Exhausthouse:
25JO
JW WI 84 A
Exhausthouse outlet diameter: 65 mm internal with connection flange for downpipe.
(I think the seller measured the diameter of intake and output opening)
Bearinghouse:
BSAF 1
F 6
The Turbo needs an external wastegate.
I really could not find any useful information about this turbo on the Internet, or if it is useful for a Datsun L28. I hope you turbo guys could help me out on this.
Rick
