Guest snakeo2 Posted December 2, 2005 Share Posted December 2, 2005 Hello all, newbie here, if this question has been asked before, please forgive me, basically I recently bought a 74 260Z and in the process of restoring it to its glory days. I've decided to swap the engines and came across a guy here in miami that has 83 or 84 ZX Turboengine for sale. The catch is that the guy does not want to sell the Turbocharger. I was wondering what type of Turbocharger can I buy for this particular engine and is a reasonable price that I should expect to pay? Also would it be as simple as just buying the Turbocharger and bolted onto the engine? One last question, what would be the output (HP) of this engine with the turbocharger? After much thought I decided that it would be cheaper to buy this engine than to try rebuilding the stock engine that came with the car. Not to mention that I can get more power out of the engine I'm planning on buying with little modifications. Any advise will be appreciated. Quote Link to comment Share on other sites More sharing options...
Dnaught14 Posted December 2, 2005 Share Posted December 2, 2005 Go to the turbo section under engine componets and read the turbo faq sticky at the top of the forum. This will give you alot of info if you are going in the turbo route. Also do a search, there is a ton of valuable information. The stock turbo was a t3 and the engine puts out around 180hp and 200lbs of torque. Welcome to the page, always search before you ask, its most likly been covered before. Good luck with the swap. Quote Link to comment Share on other sites More sharing options...
Guest snakeo2 Posted December 5, 2005 Share Posted December 5, 2005 Thanks for the great tip. I will go to the turbo section and research the topic. Quote Link to comment Share on other sites More sharing options...
Drax240z Posted December 5, 2005 Share Posted December 5, 2005 Be warned that an 83 zx turbo is a 2.8L inline 6, and a 84 zx turbo is a 3.0L V6 and not at all a bolt in into the earlier cars... Quote Link to comment Share on other sites More sharing options...
