RB 30 block w/26 head-build sheet ?
Vintage-TechZ
After searching/reading through numerous Rb threads.....I wanted to inquire about the PARTS and steps needed to build the RB26 with a 30 block ?
Is the 30 crank maintaned?
Is the block unmoddified ?
Is it straight bolt-on ?
Same rod size ?From wich block used ?
Gasket sets cross reference ?
And for THOSE actually sourcing parts and DOING the build etc.................what have you found to be relavant towards this direction ?
Are there good results posted and of what final HP and torque ?
What turbo/turbo's selected ?
MAnifolds used ?
You get the Idea......just a thread to catalogue the RB30 build and things needed to do it....along with knowledge of final results and performance.
Keep it to subject,thanks.......Vinny 8)
This thread from Skylines Down Under is the best source of info I have found. Currently it is at 158 pages. Lots of reading.
http://www.skylinesaustralia.com/forums/index.php?showtopic=15420
Cubes has put together a pdf file you most likely have already seen.
Slowly but surely I am setting up a website to document the progress of my RB30/26 build. Now I just need the time to do everything. The site is still under heavy construction.
http://www.fairladyzg.com/engine.htm
Exellent.............looks like some good studying for me ! Thanks Stealth !
Tfreer85.....your pm'd !
...........Vinny
