srgunz Posted December 28, 2005 Share Posted December 28, 2005 I have an E88 head with this camshaft. Does anybody have an idea as to manufacturer. I would like to have the specs. Thanks. Quote Link to comment Share on other sites More sharing options...
Guest iskone Posted December 29, 2005 Share Posted December 29, 2005 If you have no luck take it to a machine shop. I had the same problem and got my cam specs for $20 on the first cam and free on the next one (I was also having work done) Isk Quote Link to comment Share on other sites More sharing options...
HakosukaJD Posted December 29, 2005 Share Posted December 29, 2005 LOL.... At least you have markings. I was trying to figure out what was in mine the other day and nothing is marked on the end. The only thing stamped on mine (and at about the midpoint) was "HKS" and "L20". Funny considering it's an N42 block and head.....hmmm. *HIJACK WARNING* What do you have valve lash set at? "How to Rebuild..." says (I believe) .20mm In .24mm ex cold.....but I've been told by local builders .25 across the board on an aftermarket cam.....*HIJACK WARNING* -Sorry 'bout that I have an E88 head with this camshaft. Does anybody have an idea as to manufacturer. I would like to have the specs. Thanks. Quote Link to comment Share on other sites More sharing options...
Guest iskone Posted December 29, 2005 Share Posted December 29, 2005 L20? You couldn't find the specs with that? Isk Quote Link to comment Share on other sites More sharing options...
HakosukaJD Posted December 29, 2005 Share Posted December 29, 2005 LOL. I'm eternally hopeful that it isn't a standard L20 grind...maybe a regrind on an L20. Can you use an L20 grind on an L28? How does it run? L20? You couldn't find the specs with that? Isk Quote Link to comment Share on other sites More sharing options...
cobraz240z Posted January 26, 2006 Share Posted January 26, 2006 i might be a crane cams or comp cams Quote Link to comment Share on other sites More sharing options...
