violacleff Posted January 8, 2006 Share Posted January 8, 2006 I know that burning oil is due to bad seals. Does this necesarrily mean that the motor is on it's way out, or could you drive a car like that for a while provided you changed the spark plugs and oil often? Quote Link to comment Share on other sites More sharing options...
Lvcien Posted January 8, 2006 Share Posted January 8, 2006 I'm driving my thunderbird with bad seals... eats about a quart or so every 500 miles..haven't had any related problems. Quote Link to comment Share on other sites More sharing options...
spork Posted January 8, 2006 Share Posted January 8, 2006 well, I guess it depends on which "seals" you are talking about. Bad valve gide seals is an easy fix and you're out only $20 if you do it yourself. If your turbo is the culprit, then it needs rebuilt, or you need to figure out if you're getting excessive blow-by and causing the seals yo unseat in the turbo. Another option would be piston oil rings with a bad seal. If oil is leaking by the rings then it most likely is time to tear it down and check things out. Quote Link to comment Share on other sites More sharing options...
