floor pan difference....
FEnatic
Hi,
I've installed both types. The major differences in the profile down the centers where the rail runs along.
Early model floor pans have a "Hump" running front to back and the floor rail flanges are both the same depth.
Later 280z model pans dont have the "hump" and the frame rail has differing depth on the flanges on each side.
If you have only the floor pans and not the rails, the floors could be interchanged. But it would mean you'd have to make some adjustments when fabricating floor rails.
Yea Z-tard is correct about the lump for the cat. shouldnt be a problem though if its not rotted around that area. Just cut the pans to fit around it.
As for selling off the early model pans to fit the 280. If your OK with not having the absolute correct frame rails visually, AND can fit the frame rails to match the engine bay rails, you should be OK to go.
If you're at all unsure about doing the extra work to fit them, then yes sell the ones you have and buy the correct year pans and rails. At least this way you can 100% sure about the fit and finish.
And you wont be sick to your stomach every time you look under the car and see the wrong parts there knowing you could have made it better. (Dont ask me how I know this!!!)
