Oil Leaky into carb throats
Guest SuperDave1225
Guest SuperDave1225
Yes, I noticed my damper oil level was very low (maybe dry???) so
put more in (72 4-screw SU's rebuilt by ZTherapy last summer).
After doing a piston drop test noticed the fresh oil leaky into
each carb's throat....How can I fix this problem?????
Thx for everyone's replies...Dave
Were they overfilled? There's a mark on the plunger. Monitor the rate of oil loss, maybe diligent maintenance will keep them full. Low oil will make for lean running off idle. I recommend using whatever oil you use in the engine and tune accordingly. That way you'll never run out of or have to carry "special" oil.
