from point to hei ?
Guest jonnyoldsmobile
I am in the wireing stage now and i cant figer out what wire or how to wire my hei distrobuter. I have a 1981 280zx 2+2. Chevey 350. Do i use the blk/wht wire from the original coil. Also do i have to keep the comp/ im my car. Any help would be of grate use to make this 4 year dream come true. thanks
Yes, also use the white(?) wire for the tachometer. It's the exact same wiring. You might be pleased to find that you don't have to wire a resistor inline with the negative (tach) wire. I bought a resistor like JTR said and my tach wouldn't work at all so I took it out and it worked fine (this is only regarding ZX's). Of course you will still have to calibrate it on the back but it might work without jumping.
4 years is crazy. It's exciting to hear that you're getting close. :)
