MIKE I GOT TO HAVE ONE
Mike, i have been debating on the rear end
situation. now that i see yours i got to
have one! can i get the exact dimensions
of that unit. I have a race car shop that will do the work, but if got the axle
cut and had it ready for him it would save me tons of money! do you have the dimensions?
Myron
Myron, I don't have the exact dimensions here at work, but at home I do. This varies with rim and tire width, and how much room you want on each side of the tire. It also depends on how wide your frame tubbing is and how wide appart your frames are. Your best bet to get the exact dimension ( this is what I did ) is cut out your floor and old frame, and place the tire/wheel combo you are going to use under the car where you want it. Then measure from inside wheel to wheel. This will be your complete rear end drum to drum.( or disc to disc).
My goal is to have street/low profile tires
on some really big rims 20x10 or something close. I like the width and look of the combo used on a viper. I like playing on the street,however when i tub it i would like
to be able get some slicks under it and run it at the track every now and then
  • 4 years later...
