Fuel Pump Update...
Holley Blue pump = GARBAGE! I set the fuel pressure to 6 psi out of my holley regulator on first start up at idle. It stays nice and constant...no problems. After about 30 min of driving...my pump sounds different, like its slowing down and i have about 3 PSI at idle...If i reset the regulator so i have 6 psi again and let it sit for the night, its at around 12 psi when i start it up again the next day...Looking for a new fuel pump currently.
Im interested in this edelbrock pump. Its recomended for the Edelbrock AVS carb that i have currently installed. I want to keep the holley regulator installed because i want to keep the dual inlet and both carb run the dual inlet.
Comments?:
EDL-1791
Brand: Edelbrock
Product Line: Edelbrock Electric Fuel Pumps
Free Flow Rate: 120 gph
Maximum Pressure (psi): 6 1/2
Inlet Size: 3/8 in. NPT
Inlet Quantity: Single
Inlet Attachment: Female threads
Outlet Size: 3/8 in. NPT
Outlet Quantity: Single
$127.88
-OR-
EDL-1792
Brand: Edelbrock
Free Flow Rate: 160 gph
Maximum Pressure (psi): 12
Inlet Size: 1/2 in. NPT
Outlet Size: 1/2 in. NPT
$189.88
