su carb fuel fittins
Silent
alrighty, the bango / eye bolts that supply the fuel to the carbs. i was told they are 6an fuel fittins
WRONG!
i have two -6 fittings and they go no where to fitting in there.
is it a metric fitting? what size?
crimping down -6 line looks like *** under the hood when the rest of the fittings are nice and pretty
datsun didn't use AN's, as far as I know no manufacturere does and I don't even think they were available back then, you can use AN fittings if you have the propper adapter fitting, I believe it's a brittish pipe thread but a metric was close enough to work, just find a local speed shop with metric-AN adapters in stock and match it up
Yeah I did it. I think I used the Delorto carb adapter from Aeroquip. It is a straight thread on the carb bowl, not tappered pipe. I think is is something like M12 X 1.00 or close to that. Pull your Banjo bolt of your carb and use an open end wrench over the threads to measure it.
showphoto.php?photo=4656&size=big&cat=&ppuser=8912
