L28E vs L28ET head gaskets
thehelix112
Guys,
After blowing 2 head gaskets in quick succession with not much detonation I started to think something was up. Low and behold the L28E head gasket I ordered last time blocks two water jackets between #2,3 and #5,6 on my F54/P90. Which would account for blowing #2,3 this time, and #5 last time.
I just got a hold of the L28ET VRS kit (PN A1042-P792F) and the head gasket in this one does NOT block these two water jackets! PN for this gasket is 11044-P7911 according to the slip in the VRS kit.
I also had a peer at the pic of HKS(Nismo?) 2mm head gasket
s3011044x
and this gasket looks like it has the water jacket holes in the wrong places too.
Though interestingly, the L28ET head gasket has a lot of the holes along the top for coolant flow on the spark plug side (top in that nismo pic) blanked off.
Will be interesting to see how this one goes.
Dave
  • 3 years later...
Guest Rolling Parts
Guys,
After blowing 2 head gaskets in quick succession with not much detonation ...
Detonation?
ANY pre-ignition is a bad thing no matter what gasket is used!
Is this a turbocharged engine? How are you controlling your spark and your fuel at boost? Do you have a wideband O2 sensor to confirm the mixture?
As far as cooling holes, they vary even among brand names. Most times it makes no difference since coolant still flows along the entirety of the head. Also it get's a bit interesting to match up when people start swapping heads and block combinations.
If you're REALLY thinking that you have a hotspot then you can dust the top of the block with something like chalk and lay a new gasket on top to mark where the the holes are. Use a drill press and a small file to "match" the gasket to the head.
I did a gasket match on the last turbo engine I built this summer but to be honest I don't have 6 temp probes along the head(so I can't tell if it's really having any impact on a cylinder to cylinder basis). I can't tell any difference in drivability but then this one is a MegaSquirt II engine and I've adjusted fuel/spark to not detonate with the fuel I'm using.
Detonation?
Still, If the head is straight, it takes A LOT too break a head gasket, and if its a Nissan gasket, they handle A LOT in my experience. Unless theres a Whooole lot of HP in there, or SEVERE detonation, I dont think detonation is his problem....
Guest Rolling Parts
Still, If the head is straight....
If the problem was isolated to one end of the head, I'd agree.
I'm assuming he's checked both head and block and installing it to spec because that's the right way to do it.
Agreed. Any parts with bendscracks and so on can cause these issues. Also, a bended head typically causes problems on the center cylinders, 2-5, and especially 3 and 4.
Guest Rolling Parts
AH! True. I guess I never had a head with a really nasty twist. I never thought of that.
